Apollo 1260 64mb mod job
mjnurney
we live as we dream. Alone.
england
Milton Keynes
a customers Apollo card 1240 25mhz
now.
1260 68060
64mb mod
battery
1) remove the mach ram chip (with care)
2) cover any area affected by heat (ram socket / zorro socket)
3) use heat gun and carefully lift the semi melted mach socket away.
4) clean and tin the mach chip pads and the mach chip
5) position the mach chip back on the pads and reheat with heat gun or soldering iron
6) remove foil / protection. & inspect solder
7) clean and test
8 )fit 64mb mod socket (pins towards ram socket)
9) solder wire from under Apollo ram socket to mod PCB. (A4 pad)
10) clean & inspect
11 ) fit ram and test.
I don't have a 64mb ximm sadly but I've ordered one to test it...and a good clean to get the flux off it.
mike.
fitzsteve
Retired Slacker
Sevenoaks
Do you still have your A4000? And an A3640? Might have a job for you... If you want to take it on...
mjnurney
england
Milton Keynes
my 64 mb simm has finally arrived and I've finished soldering the card wires up and a bit of tidying - so its ready for the customer.
I've added a diagram too if anyone needs it. i routed my wires slightly differently but essentially the same.
mike.
r0jaws
Mondeo Man
Lincolnshire
Nice job buddy. I have one to do myself in the near future, this'll be a handy reference.
BTW, where did you get your RAM from? I've had a look and found some likely compatible units, but it'd be nice to be sure which one's to get.
mjnurney
england
Milton Keynes
i spent ages trying to find one but its a 64mb EDO single sided simm - its big! i had to remove the socket and solder the ROM flat to the board.
I'm sure there are small 64mb simms but i couldn't find one. i had to order one from the states.
