Closed Apollo 68040 @ 40 mhz amiga a1200 accelerator inc 16mb ram
Flynnsarcade
West Midlands
i have for sale this apollo 68040@40mhz accelerator it comes with 16mb ram and works without any issues and in very good condition.
£275 plus postage please note i have advertised elsewhere
thanks for looking
timmie
Netherlands
Utrecht
While I eventually would like to upgrade one of my A1200s from a 030 to a 040, this is a bit pricy, more so given the limited amount of RAM. Too bad, I have to skip this.
roy_bates
resistance is futile!
england
birmingham
im not interested or anything,but i thought i would mention to the owner that the battery has started to leak, if it isnt removed soon this card will need repairing.
best of luck.
milo
Germany
Niedersachsen
And i have send Fynnsarcade a Pm that the Apollo is not in good condition about that the Apollo have a Accu Damage. The Chip F08 must replace and clean the PCB.
Flynnsarcade
West Midlands
while I value the comments the leak has now been cleaned up and the battery removed
can anyone recommend a battery for this?
Rick
Germany
West
A VL2020 is good - needs a little care to mount it properly but works perfectly. :)
No! You destroy the VL2020 Cell, because the 2020 is a 3 Volt Cell, and the Apollo Card will load the Cell with 3,8 Volt. Read carefully the Datasheet before you post dangerous Information.....
retrodave
Wales, UK
West Glamorgan
Then my apologies to all, I believed it was suitable :( I'll go check the specs. Can someone suggest a replacement instead?
(edit: FWIW I initially took my information from a thread on Amiga.org entitled 'Apollo 1240 battery & fan questions' where stachu had done a similar thing. I'm sure the voltage could be reduced if this were a problem)
(final edit: :) The VL2020 is suitable... but Rick is right, anyone looking to use one as a replacement battery must limit the voltage to it to prevent charging damage. Adding a 3.3V zener diode in parallel to the VL2020 (and swapping one of the two diodes in the board's charging circuit for a 330-ohm resistor) solves the problem! :) Hope this helps other 1240 owners, and good luck with the new battery Flynnsarcade!)
