Arcade Supergun
TheLastBandit
Ireland
Meath
Supergun with support for console controllers & kickharnesses
No pad hacks, just a simple adapter cable lets you connect the following controllers to the supergun. Player 1 & Player 2 can use different controller types simultaneously.
  • Sega Megadrive (3 & 6 button)
  • Sega Saturn
  • Sony Playstation (Digital, Dual Shock 1 & 2)
  • NES
  • SNES
  • PC-Engine
  • Turbo Grafx
  • Neo Geo (no adapter cable required)
Any controller with more then 3 buttons have the extra buttons routed to the game board via the 'Expansion' connector and appropriate kick harness cable. Typically 'Start' & 'Select' on the controllers are mapped to 'Coin-Up' and 'Player Start'.
Different user select-able button mappings available for Playstation, SNES, Saturn, Megadrive pads.
Multiple audio input sources
The audio source is user selectable between "Jamma / Stereo / MVS".
Jamma takes the amplified Mono audio converts it to line level and is routed to both Left and Right SCART outputs.
Stereo takes amplified stereo audio from the game board via the 'Expansion' connector and converts it to line level before routing to Left and Right SCART outputs respectively.
MVS takes the amplified stereo audio from the Jamma connector, converts to line level and sends it to the SCART Left and Right outputs.
Line-In jack overrides the audio switch 'S1' selection and passes the (Line level) audio straight to the SCART outputs.
Line-Out jack lets you send the output audio to an external amp or headphones.
Kickharness support
The 'Expansion' connector lets you connect to game boards to use Buttons 4,5,6 for Players 1 & 2. Button 4 is also mapped to the Jamma connector for MVS boards.
Kickharnesses can be made up for pretty much any board type.
Multi-in-1 board support
Buttons 5 and 6 are connected to the Jamma edge via a pair of switches so can be enabled and disabled as needed for use with the various multi-game boards that have all 6 buttons on the Jamma edge.
Autofire
Buttons 1-6 have an autofire feature, can be enabled and disable by hold 'Start' for a few seconds.
Other features
Terminal block power input so can use Jamma PSU or ATX PSU (with adapter cable)
On-board controls for 'Test', 'Service', 'Coin' and RGB adjustment.
All cable pinouts available so you can make your own adapter cables
€90 Supergun + ATX adapter + 1 controller cable
€12 Controller cable
€12 Kickharness
Street Fighter - Capcom CPS1 with kickharness, Dual Shock 2 & Sega Saturn controllers.
NeoGeo MVS with NeoGeo and SNES controllers
Soul Edge - Namco System 11 with Sega Megadrive and Playstation Dualshock controllers
Street Fighter - Capcom CPS2 with kickharness, Sega Saturn & Megadrive controllers
