Closed ASUS P5N-E SLI Motherboard Socket 775
  • Thread starter Thread starter AmiNeo
  • Replies Replies 2
  • Views Views 1944
AmiNeo
CodeMonkey
Kendal, Cumbria
Hey Amibayers! I have up for grabs my ASUS P5N-E SLI motherboard. + Driver CD and the rear ports blanking plate shield thingy whatchimicallit (forgot its propper name :lol:) that sits around the ports at the rear.
This is IMO one of the best 775 boards with a host of features including options for overclocking pretty much everything overclockable including the memory so if you bought any memory above the supported 800MHz (1066 for example) all you would need to do is set the memory speed manually).
I replaced the thermal grease under the heatsinks on the motherboard about a couple of months ago with some AS5 to keep her running in top shape. This is hands down the best motherboard I ever owned.
Latest BIOS was also installed before I upgraded to a Q6600 about 6 months back.
Selling due to recent upgrade to LGA 1155.
Tech specs:
General
This board features advanced manual options that aid in overclocking and performance-tuning efforts.
Product Type Motherboard - ATX
Cache Memory None
Chipset Type NVIDIA nForce 650i SLI
Max Bus Speed 1333.0 MHz
Processor Socket LGA775 Socket
Max Processors 1
Compatible Processors:
Core 2 Extreme,
Pentium 4,
Core 2 Quad,
Pentium D,
Celeron D,
Core 2 Duo
Memory
Max Supported Memory 8.0 GB
Supported RAM Technology DDR2 SDRAM
Supported RAM Speed 800 MHz,
533 MHz,
667 MHz
Supported RAM Integrity Check Non-ECC
Supported RAM (Registered or Buffered) Unbuffered
RAM Features Dual channel memory architecture
Audio
Type 6-channel
Audio Codec Realtek ALC883
LAN
Network Controller Marvell Alaska 88E1116
Network Interfaces Gigabit Ethernet
Modem None
Expansion / Connectivity
Expansion Slot(s) 1.0 x PCI Express x1 - LGA775 Socket ( SLI: x8, x8 mode; single card: x16, x1 mode ),
4.0 x PCI - DIMM 240-pin,
2.0 x PCI Express x16,
2.0 x Processor,
1.0 x Memory
Storage Interfaces JMicron JMB360 : Serial ATA-300 - connector(s): 2 x 40pin IDC - 4.0 device(s) - RAID 0 / RAID 1 / RAID 0+1 / RAID 5 / JBOD,
ATA-133 - connector(s): 1 x 7pin external SATA - 4.0 device(s),
Serial ATA-300 - connector(s): 4 x 7pin Serial ATA
Interfaces 6.0 x Audio - Generic - 6 pin mini-DIN (PS/2 style),
1.0 x Parallel - Line-out (center/subwoofer)/microphone - Mini-phone stereo 3.5 mm,
1.0 x Network - IEEE 1284 (EPP/ECP) - 4 pin MPC,
1.0 x Audio - Ethernet 10Base-T/100Base-TX/1000Base-T - 34 pin IDC,
1.0 x Keyboard - Floppy interface - 6 pin FireWire,
1.0 x Audio - SPDIF output - Mini-phone 3.5 mm,
1.0 x Mouse - Line-out (rear)/line-in - 7 pin external Serial ATA,
1.0 x Hi-Speed USB - Line-in - Mini-phone stereo 3.5 mm,
1.0 x Storage - eSATA - RJ-45,
1.0 x Audio - Generic - RCA,
1.0 x IEEE 1394 (FireWire) - Line-out - 4 pin USB Type A,
1.0 x Storage - 6 pin mini-DIN (PS/2 style),
1.0 x Audio - 25 pin D-Sub (DB-25)
Additional Connectors (Optional) 1 x IEEE 1394 (FireWire),
2 x Hi-Speed USB
Power Connectors 4-pin ATX12V connector,
24-pin main power connector
Features
BIOS Type Award
BIOS Features WfM 2.0 support,
Hyper-Threading Technology,
ASUS EZ Flash 2,
SMBIOS 2.3 support,
DMI 2.0 support,
ASUS O.C. Profile
Manual Settings Memory voltage,
CPU frequency,
PCI Express x16 slot frequency,
Processor core voltage,
Chipset voltage
Sleep / Wake Up Keyboard wake up,
Wake on USB port,
Wake on LAN (WOL),
Mouse wake up,
Wake on ring (WOR)
Hardware Features Chassis intrusion detection,
NVIDIA SLI Technology Support,
ASUS SATA on the Go,
ASUS Q-Connector,
C.P.R. (CPU Parameter Recall),
CrashFree BIOS 2,
Heat pipe chipset cooling
Miscellaneous
Cables Included 1.0 x Serial ATA cable,
1.0 x IDE cable,
1.0 x Floppy cable,
2.0 x USB panel,
SLI bridge
Software Included ASUS PC Probe 2,
Drivers & utilities,
ASUS Live Update
Microsoft Certifications Certified for Windows Vista
Compliant Standards RoHS,
Plug and Play
Width 12.0 in
Depth 9.0 in
Asking £52 - postage included in UK.
Although I no longer have the original box, she will be delivered in an anti static bag, and well protected with lots of softness inside the package.
EDIT: Price drop...
