For Sale Atari Falcon 030 Extreme adapter VGA/ST mode with DB19 female
  • Thread starter Thread starter axel81
  • Replies Replies 31
  • Views Views 1770
View attachment 2510626View attachment 2510627
I made this version "Atari Falcon 030 Extreme adapter VGA/ST" which differs from many versions in that it uses a real female DB19 connector and everything is contained inside the original shell.
Jumper has also been provided to select the mode of use (VGA or ST) which allows you to connect a 15/30KHz (VGA) or 15KHz compatible monitor (ST mode) as you wish.Finally, it is also possible to add a 3.5mm audio cable of approximately 1m to carry the audio out
I mean that it is the World smallest, sturdy and extremely reliable Atari Falcon030 video to VGA/ST adapter, that allows you to connect modern VGA monitors to your Atari computer (15/30KHz for VGA mode or 15KHz for ST mode)
  • Original DB19 female connector
  • Original Cover shell for DB19
  • Anchor screws for Atari side and for VGA cable
  • Jumper selector for ST/VGA mode
  • Optional: audio output cable with 3.5mm 1m lenght aprox (+6€)
PRICE --> 39€
Hi do you have these still available. Would you ship to New Zealand?
