Closed Atari ST MEGA STE TOS v2.06 32-PIN EPROMS
  • Thread starter Thread starter johnali3n
  • Replies Replies 19
  • Views Views 5256
johnali3n
East Grinstead, West Sussex.
I have five sets of Atari ST TOS v2.06 32-pin EPROMS.
A choice of any language. Help given for fitting if required.
£15.00 + P&P per set.
Atari STE TOS v2.06 specific features for reference
Last version of Atari TOS for the 68000 line
Many bug fixes
Atari logo display at boot-up
Automatic cold boot memory test
Support for 1.4MB diskettes
6ms step rate
Better media-change detection
"NewDesk" desktop gains features from Gribnif's NeoDesk, including:-
Definable keyboard shortcuts
Install programs/files/folders as icons on desktop
Install all available drives with one operation
Automatic fitting of icons to window
Configurable desktop and window colours
File and device icons
Single-operation copy/move and rename
Windows scrollable while files selected
"Select all" command
Programs start-able with function keys
Bypass program autostart by holding down Control key
Enter special characters with Alt-[numeric keypad] combinations
File search function
File masks support
Multiple desktop configurations
Directory list printing
Unsorted view
Resolution change with Alt-[number]
7 windows allowed
Bring-window-to-top function.
Friendliest and most stable version
Preferred choice for serious ST use.
Version 2.05 incorporated
features from TOS 3.05 to harmonize the two. AKA "Mega STE TOS"
Are these a straight fit into an STe or do they require changing of jumpers / resistors?
Dependant on current jumper settings you might have to change the jumpers.
Please review the image below as reference for jumper settings:-
http://ebay.jacwebhosting.com/tos/jumpers.jpg
I supply 32-pin 27C1001 EEPROMS, so please look at the relevant jumper settings for your motherboard in the image above.
Received the ROMs today, great stuff. Feedback left.
Many Thanks,
Graham C
I can burn any version and any language of TOS you require - so please let me know which version your require for your MEGA ST and I will burn for you - same price. For the MEGA ST, the latest version of TOS you can have is TOS v1.04:-
[h=3]TOS 1[edit][/h]
  • 1.0 (ROM TOS) Earliest version released on disk. First ROM release of TOS.
    • Formats: floppy, 2 chip and 6 chip ROMs (192 KB)
    • Rom date: 20 Nov 1985
    • Machines: 520ST, 1040ST
  • 1.02 (MEGA TOS) fixed bugs, supported Blitter co-processor and real-time clock.
    • Formats: 2 chip and 6 chip ROMs (192 KB)
    • Rom date: 22 Apr 1987
    • Machines: 520ST, 1040ST, Mega 2, Mega 4
  • 1.04 (RAINBOW TOS) Many bug fixes, file selector changed, DOS-compatible disk formatting, much improved performance. However, compatibility problems with older software.
    • Rom date: 6 Apr 1989
    • Machines: 520ST, 1040ST, Mega 2, Mega 4, Stacy
  • 1.06 (STE TOS, Revision 1) Support for STe machines only. Needed STE_FIX.PRG to patch bugs.
    • Format: 2 chip ROMs (256 KB)
    • Rom date: 29 Jul 1989
    • Machines: 520STE, 1040 STE
  • 1.62 (STE TOS, Revision 2) bug fixes for the previous 1.06 STE TOS.
    • Rom date: 1 Jan 1990
[h=3]TOS 2[edit][/h]
  • 2.02 Early TOS release for Mega STE.
  • 2.05 (Mega STE TOS) Only found in the Mega STE with 720K floppy drive.
    • Rom date: 5 Dec 1990
    • Machines: Mega STE
  • 2.06 (ST/STE TOS) Last TOS version for ST/STE computers. Bug fixes, 1.44 MB disk support, memory test. Adds GTP program support (GEM-Takes-Parameters). Greatly enhanced GEM GUI. IDE hard disk booting. Atari logo display at boot-up. Automatic cold boot memory test. Supports higher resolutions.
    • Rom date: 14 Nov 1991
    • Machines: 520ST, 1040ST, 520STE, 1040STE
  • 2.07 used on the Falcon prototype "FX-1"
  • 2.08 used in notebook ST. ROM also contains some notebook-specific utilities: STTRANS (null-modem/ parallel-cable data transfer), power management tools, hard disk drive tools and drivers (AHDI, XHDI, BOOKINST and BOOKFMT) and a RAMdisk installer.
[h=3]TOS 3[edit][/h]
  • 3.01, 3.05, 3.06 (TT TOS) Primarily for 68030 TT support only. Supports fast "TT RAM", special TT screen resolutions etc. ST-hardware-compatible "Line-A" API dropped for extended TT functionality, forcing programmers to use GEM-compliant VDI calls etc. and thus encouraging GEM-compatible (as opposed to ST-compatible) development.
    • Format: 4 chip ROMs (512 KB)
[h=3]TOS 4[edit][/h]
TOS 4.92 (with German language selected)​
  • 4.00, 4.01, 4.02, 4.04 (512 KB) Update for Falcon 030 machines only. 68030 only. Adds support for DSP, 16 MHz blitter and video overlay. New v3.40 AES (last single-tasking version, but MiNT/MultiTOS-multitasking-aware) supports: pop-up menus, 3D window and dialog objects (later modified to use more compatible ob_state flags instead of extended type), 256-colour "animated" icons, soft-loaded fonts, inter-app drag&drop, background window manipulation, extensible filesystems. New CPX module for international localisation configuration. V4.04 was the last official Atari version of TOS.
  • 4.9x (4.92, 4.98) Never officially released, though prototypes were leaked and subsequently shared illegally.
TOS 4.92 was a version of MultiTOS, the Multitasking version of TOS, in a format (.img) which was designed to be written to a ROM chip. TOS 4 ROM contains five, user-selectable language versions.
