Atari ST/STE/STFM Universal Floppy Disk Drive / GOTEK adapter cable with ORIGINAL 14 Pin (DELUXE)
I wanted to make a DIN14 to IDC34 adapter different from those that can be found online, but above all universal for GOTEK or universal PC floppy : therefore here is my "DELUXE VERSION"
PRICE --> 39€
Please noe that USB adapter cable is needed in order to power up your external floppy disk drive/Gotek!
This cable is not included but I can do it for you for 10€
--> A stylish and robust professional version for your ATARI <--
- You can use this external floppy drive adapter for the Atari ST/STFM/STE. This has been also designed in order to use any kind of external hard drive like SD4ST,ecc
- This will show up as drive B on the GEM desktop. Please note that there needs to be an internal drive in the ST for it to allow drive B to work (at least in the ones I've tried, although they are all various iterations of STFM so the STE may be different). It doesn't look like it has to work, it just has to be there and hooked up. Please note this'll work fine with the original ST/M but you won't be able to use an SD4ST at the same time because of the layout on the rear. For the original ST/M with no internal drive it'll show up as A and will be bootable.
- As above I've tried this with a Gotek and it works fine as expected. I've also tried it with a regular floppy drive that was nabbed out of an external drive and that loads disks fine. So as long as it doesn't need +12V it'll work fine with the adapter.
- There is also a jumper selection in order to invert the floppy ID numbers (ID0/ID1) so you can switch their position to use unmodified PC floppy drives easily!
- Please note that I'm using original 14 pin connector for the best for a certain and safe contact with the Atari port!
- Cable lenght approx 50cm..this means that you can place your FLOPPY DRIVE right next to your ATARI!
PRICE --> 39€
