ATX PSU in original Amiga PSU casing
  • Thread starter Thread starter TTSAddict
  • Views Views 1027
TTSAddict
Germany
Niedersachsen
Using an ATX PSU to power Amigas is propably old news for you folks, but I'd like to share this specific one because it uses the original PSU casing.
I wanted to do this for a long time and finally mustered up enough energy to tackle this.
I have five Amiga PSUs, three of them are the lightweight ones without epoxy, so that part was easy enough.
When I was browsing my junk, I came across this specific PSU from Zalman, a ZM350-FX. I don't know why I bought this in the first place, I only remember it being a mispurchase originally. Later I powered a router via its 12V rail, it didn't even get lukewarm; the fan is temperature regulated, and it uses a rather small scale design. Looks like its an ideal candidate.
Removing the guts from its casing didn't proof as straightforward as one might imagine. There are parts for interference supression soldered directly to the kettle jack, and they also physically prevent removal of the board.
Since I don't need the casing anymore, I just bent that side down to make life easier while unsoldering, which was very tricky. The little legs of the parts were intertwined with the jack before soldering and I didn't want to break or cut them too short, so this was a hot job, which also damaged my solder tip, because I'm stupid. (Used the tip to push out the pins, which scratched the coating). Additionally, I had to cut out a part of the shielding around the jack, which was soldered to the earth/ground pin.
Testing the size
I hot glued the fan to the cover, with the pushing side up. Don't know if that can squeeze anything through the small vent holes, but I don't think it will need the fan at all anyway.
Originally I intended to use the original switch as a breaker of the mains side and an additional switch for the PS_ON signal. Also instead of hooking the red LED to 3,3v, I wanted to hook it to 3,3v_standby, a green LED to the PWR_GOOD signal and a third one directly to the fan PWM as a... kind of temperature warning, but I scrapped all that and just hooked one red LED to the active 3,3v rail. Also the original switch now just operates the PS_ON signal. The ZM350-FX originally had no power switch either. I should propably measure the standby power consumption NOW and revert to my original plan but hey...
This is the current state:
So I still need to solder the mains side. Notice that I rotated mains and secondary, since the switch operates a 5V signal now. I also needed that GN/Y wire for the shield pin, which was actually connected to ground in the original commodore design.
I will update this thread once when I'm done. I will not test this contraption on my A1200 for obvious reasons, but I have two A500 guineapigs that can put this PSU to the test.
Oh btw. I forgot to mention, the board is held down by hot glue as well.
Also, here is the complete imgur-album
Final state of the mains side:
Closed lid:
The thing powers up and gives out the expected voltages without a load/Amiga connected. Now I'm getting a reading of 80V AC from all rails to the shield pin/earth which stumps me a bit. Need to think about how to proceed before connecting anything to that.
I think I might need to connect the secondary side ground to earth as well, I presume it was like that when it was housed in its original casing through the chassis. Measuring any rail of my PC PSU to ground gives the intended DC voltage without ripple, so I think thats the norm. The current reading of the Zalman is 0V DC to earth along with the 80v AC.
Yes, looks like you need to manually connect the secondary side GND to earth, when running it outside its metal case. Voltages are okay now. Now for a test run.
