Sold Bars and Pipes Triple Play Plus MIDI interface (homemade)
  • Thread starter Thread starter Golem
  • Replies Replies 12
  • Views Views 515
Golem
Nottingham
I bought this item from here some time ago https://www.amibay.com/forum/want-t...onal-triple-play-plus-midi-connector-homemade
I never found the time to use it so I can't say if it works but I have no reason to believe otherwise as the previous owner had it working (I believe they made it too).
I offer here for the same price I paid £23 and postage of your choice.
You need to use Bars and Pipes with the appropriate software tools to take advantage of the extra MIDI channels.
Hi Lukeya I can’t see your messages you have sent they just look blank. Do you want this item?
Golem, your replies are also blank. Yes I do want the card. Can you please send me an email to <Snip>
Luke
Lukeya Try the following as it has been said it works.
Go into your profile, edit settings (on the left of the page), then from the tabs choose account,
scroll down and uncheck Use vB Messenger, then scroll to the bottom and Save Changes.
Golem, right I've adjusted my PM settings and tried again. Otherwise please use my e-mail address - yes I'll have the midi interface.
Luke
I didn't see your request for help Lukeya, this is a Dev Issue which sadly I cant help with sorry. Golem can you also try and set your messenger setting as per Watson instructions in his comment, just in case the issue is your end.
For information: if you use the @ symbol in front of a members name this will also send that user a notification that they have been mentioned in a thread.
Golem, I noticed your messaging system has changed let us know if the messaging system is working between you two now please
