Closed BBC Master Compact Disc Drive
Hi James
Do you actually have the Disc Drive / PSU Base for the compact?
If not, and these are very hard to find on their own, I can adapt an external 3.5" Floppy drive to plug directly into the port on the back of the compact.
You may also want to consider fitting an expanded MOS ROM to it do you can access DFS discs too.
The current MOS is only 64K but we can fit the full 128K easily
