BFG9060 Bootloop
  • Thread starter Thread starter nickrb
  • Replies Replies 9
  • Views Views 972
nickrb
Donator
South
I have a BFG9060 that is stuck in a boot loop.
Rainbow colors and then it reboots.
I've probably re-seated the card 10 times.
I've triple checked all jumpers.
I've cleaned the KEL contacts with IPA.
Any other advice?
View attachment IMG_8781.MOV
Any other advice?
I noticed you’re running this on a A3000. The earlier BFG cards don’t play nice with SCSI. It’s a known issue.
Worth a watch to see if this helps.
That SCSI thing is a different issue. This machine does not even boot to a kickstart screen, just boot loops with the rainbow colors.
Did the BFG ever work in this A3k? Or is this a new purchase?
Can you test the BFG in another machine to rule it out as being the issue?
Do you have a custom kickstart?
Do you have the Bootrom loaded in the flashrom ?
New purchase. BFG was thoroughly tested by the seller.
Kickstart 2.04
Does the 68060 works at all with KS2.04? I don't think so. You should try 3.1.
I like old KS 2.04 but i keep it only for my OS2.1 setup in my good old A500Plus i used back in 1991.
BFG9060 is supposed to work with KS 2.0. But I have ordered 3.2.2 to try that
Worth a look here: mentions Amiga OS 3.1 and above…..
Just to add:
Worth a read up as you will need to install and setup THORs MMULIBs as the BFG has no Autosensing for RAM.
A pitfall I had when I once owned one.. 🤔🙄
