Bi-Colour leds, anyone know how to wire them?
ElectroBlaster
Exeter, Devon
I apologise but this is something new to me!
I can wire leds, I know resisters pretty much for lowering current but never messed with leds that can emit more than one colour.
I basically want this:
Colour 1 for power, always on.
Colour 2 for drive activity, only when drives are reading.
Can this be done? I am currently sat on google trying to get the gist of what needs doing.
This will be going into an old C64 Breadbin case (orignal board is fubard). I will remove the original led and put in the bi-colour one, keeps it neat and tidy then.
EDIT: I have found these http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=170710148796. If these were red instead of clear then I will be a very happy chappy lol
It depends on what type of multi LED you chose. For simplicity I'd advise you to use a duo-LED. These have 3 pins and are essentially two LEDs in one casing. They usually have a common cathode and will allow you to have three colours in total (by illuminating LED 1, LED 2 or LED 1+2).
The current limiting resistor is calculated as with a normal LED. Both LEDs should have their own separate resistor.
Bryce.
So I will need a resister to limit them and stop things going awry?
I bascailly want a mini-itx board to power the led and also report drive activity.
Or
I could power one side of the led directly from a psu and then just connect drive activity to the board...
Just need to figure out the value of resistors I need.
Both LEDs can be seen as separate entities. The resistor depends on 3 values you need to know:
1 - The voltage (or signal voltage) that will power the LED (Vcc).
2 - The voltage the LED requires (Vled)
3 - The current the LED will require (Iled)
2 and 3 can be found in the datasheet of the LED.
Then just use R = (Vcc - Vled) / Iled
to calculate the values for each resistor.
So if the power LED is being supplied by a 9V source and the LED requires 2.2V @ 20mA (typical for green LED). Then the resistor needs to be:
R = (9 - 2.2) / 0.02 = 340 Ohms
If the activity LED is being driven by a 5V signal and the LED needs 2.0V @ 20mA (typical for red LED). Then the resistor needs to be:
R = (5 - 2) / 0.02 = 150 Ohms
However, you'll find that the 20mA given on the datasheet usually illuminates the LED to its maximum, so I usually use 10mA in my calculations... You only want to see it lighting and not be blinded by it.
Bryce.
Thanks :D
Really good info.
Same thing with the brightness! I dont want to be blinded by it, just enougth so it tells you things are on and doing the job.
I would like to use the mini-itx board header for this job if possible.
EDIT: I just browsing the tech docs for the board I have and it seems it can drive a dual-led by default! It states the pins can be connected to a single or dual coloured led. Also the the voltage seems to be 5v which I assume is the same as all pc motherboards?
Back on track with this!
Got some more info:
http://www.alldatasheet.com/view.jsp?Searchword=L-59EGW
  • LED, 5MM RED/GREEN, 3MCD/8MCD
  • Bulb Size: T-1 3/4 (5mm)
  • LED Colour: Red, Green
  • Luminous Intensity / Colour: R 3mcd, G 8mcd
  • Viewing Angle: 60°
  • Forward Voltage / Colour: R 2V, G 2.2V
  • Forward Current / Colour: R 30mA, G 25mA
  • LED Mounting: Through Hole
  • Lens Shape: Round
  • Wavelength / Colour: R 617nm, G 568nm
  • MSL: -
  • SVHC: No SVHC (20-Jun-2013)
And my board is:
http://www.intel.com/content/www/us/en/motherboards/desktop-motherboards/desktop-board-dn2800mt.html
Just trying to suss out what voltage is coming from the motherboard headers. I read something about this board being able to drive dual-colour leds... but unsure what voltage its pumping out?
EDIT: The manual states, Front Panel Header of 9pins - HDD Activity Pull-Up resister (750) to +5V. Nothing stated for Power Led other than it can drive a dual-led but I now assume that is for power alone?
click on "interactive layout" then hover over "17" on the picture;)
youll see what i mean.:)
do you have the board already?
Motherboards normally have the resistors on board for the LED headers so all you need to do is to attach an LED to the pins, however, you can put a resistor in series with it if you want to reduce the brightness even further.
If two LEDs are arranged like this on the header:
then you can simply connect a 3-pin dual LED on the left three pins:
(apologize for bad ascii gfx :))
