RetroNinja
I imagine that Commodore used the same floppy setup throughout the line of Amigas. This is more of a sanity check. Ignoring the lack of length, can I use the same floppy cable in an A2000, A3000, A4000?
Rabbit hole...
This has more to do with verifying pin1 on mobo in relation to the drives. Standard A2000 floppy cables have the key tab on one side for the drives and the other side for the mobo. I *think* this is to address the A2000 position of pin1 on the mobo floppy header. If that is the case then are all other big box Amigas wired the same?
Rabbit hole...
