Bizzard scsi
rs2klee
U.K
London
just installed my scsi card in the blizzard 030 mk iv board but cant get it to see any disks? anyone got this setup with a cd rom drive and got it to work?
Harrison
West Sussex
Have you installed the scsi device and the CD0: device for the CD-rom drive, and edited the tooltype for it to point to the scsi device driver for the blizzard scsi?
Slayer
New Zealand
Dunedin
Might seem like stating the obvious but have you changed the tooltype in the HD software you are using to point at blizzard1230.device or whatever it is called?
If its to do with a CDRom drive perhaps you have to mount it or run some preference software etc...
and if all else fails,locate a pdf of the manual :nod:
Sorry for not being specific just being general
Zetr0
Ya' Like it Retr0?
@rs2klee
lets check the simple first.
edit the icon information of "hdtoolsbox" found in "tools" from "scsi.device" to "1230scsi.device" and then save and exit.
(normally I copy the icon and then rename it for the device I will be using, i.e GVP_HDtoolsBox, IDE_HDToolsBox etc etc.)
Now assuming that you have correctly terminated the SCSI chain (this can be done via the last device in the chain to have TERM ON or an actual SCSI terminator
hope that helps
---------- Post added at 03:08 ---------- Previous post was at 02:56 ----------
ooohh...CDROM.. I thought you where setting up a hard disk
hell this should be a piece of cake =D
okay... download amicdfs240 from aminet.
Code:
1. Copy AmiCDFS:L/amicdfs.030 or amicdfs.060 (pending your cpu) to HD0:L/
[B]rename this file as amicdfs[/B]
2. Copy AmiCDFS:C/SetCDFS to HD0:C/
3. Copy AmiCDFS:CD0 to Devs:DosHandlers/
4. Edit Devs:DosHandlers/CD0
5. Change "device = scsi.device" to "device name = 1230scsi.device"
6. Change "unit = 1" to "unit = (insert SCSI Unit ID)"
7. Change "BufMemType = 1" to "BufMemType = 5"
8. Save Changes and exit.
9. reboot amiga
10 put a disk in the drive and give it a moment =)
11 = party =D
