BlizKick tutorial?
  • Thread starter Thread starter wanderer
  • Replies Replies 3
  • Views Views 1006
wanderer
usa
CA
I have a 1200 with a 1230 MK4 Blizzard card, and I want to switch the kickstart to boot old software from a 1.3 hard drive image (basically it is a CF card that contains 1.3 OS and software; which won't run using 3.1 roms).
I know about relokick and other variants of rom boot applications, but my blizzard card has a mode to boot from a different rom, using BlizKick. Got that from aminet but now I have no clue how to use it. From some info collected online I understand that I need to add to the startup-sequence on the 1.3 hard drive image, the line to have BlizKick to load the 1.3 rom, although I have no idea how to do that; and I found no tutorials about how to use BlizKick.
Does anyone have info about how to use it or where to find step by step instructions? Thanks
From what I recall you have to call each module individually, it was quite a pain to setup all the OS3.9 modules although I did get it working eventually. It's probably easier just to use a Relokick Disk. The included docs should explain the process.
Note that your mileage may vary even with 1.3 rom it may not run due to the advanced chipset.
Thanks; so the whole setup is not something simple to do I guess. I never used this application so I am totally clueless. BTW I am using 3.1 ROM with 3.1 WB currently; not sure if that is simpler than 3.9.
What are the downside of a relokick? I was told that it is not as good as using Blizkick since that won't reside in fast mem but in chip mem
Blizkick is a good piece of software if your accelerator will work with it.
Syntax is:
Blizkick <rom file name> CPUCARD QUIET
So in my A4000, the first line of startup sequence is:
C:/Blizkick Devs:314.rom CPUCARD QUIET
And boom, 3.1.4 rom gets loaded and its just like having actual roms installed into the machine.
