Blizzard 1240/1260
Marc
Essex
Is it possible to move the processor on the top side of the card rather than the bottom? I like the apollo design of the processor on top, it just makes more sense in terms heat.
No, not possible: the connections will become inverted and the CPU will fry as soon as the Amiga power up.
Tomse
RISK is good
Denmark
Copenhagen
short answer no,
long answer yes..
you'll need to work ALOT to make it work you need to make 1 to 1 pin connection which involves alot of wires or a pcb.. the CPU will be higher , you'll have a birdsnest of wires and you probably will solder one or more wires to the wrong leg.
This picture is very simplified (Taken from Cosmos' blogspot, see link below)
http://cosmosamiga.blogspot.com/2010/08/cyberstorm-mkii-speedup.html
