*Sigh*, you know, I was told not to install Boingbags 3 and 4 as they are buggy garbage (apparently)... but I did anywayz.
When installing BB3 it opens your SS and tells to install a couple of lines early on to load the new modules. Strangely, BB4 didnt require this.
I did this. But upon first boot it failed with the error message that version such and such of (I cant remember the library or device) was already resident. So I deleted this device/lib from the loadmodules line and rebooted. Happened again with the next new module trying to load, so I removed it.
This time it booted (must not have had the other devs/libs in memory) once at wb I think to myself "Well, these custom KS 3.9 roms must have BB3 and BB4 built in" so I deleted the entire loadmodules line.
System booted fine and wb version is still 45.5 and ks is still 45.59.
So all must be well. But.... since then I have discovered two small problems and I am starting to think they have something to do with the resident icon.library or such.
1 - When I right click on a volume and try and format the system simply locks, not crashes. Yet, running format from the icon is fine.
2 - When I right click on an icon and select Information, then drag and drop another icon on top of the icon image to replace it... it will only work if the new icon image is only 32 colours or less. If I drag and drop a 256 colour icon I ge the message "not of required type"
If I run IconEdit and load the images, they come up as blank - sort of like if you try and view a new icon without the newicon patch (on older systems).
Neither of these problems existed before installing BB3/BB4.
Perhaps I should not have deleted that line from te startup sequence?
Oh, and Im running PowerIcons patch too. I am only using standard 256 colour icons, but the colours are not correct unless I use the PowerIcon patch.
The PowerIcons patch slows down the system though, is there any other way of correctly displaying 256 colours icons? Surely WB should be able to do this itself?
ANY help would be appreciated.
