For Sale Brackets (FDD typ1, FDD typ 2, HDD and Zorro/PCI) for Amiga 3000D
  • Thread starter Thread starter arymanx
  • Replies Replies 52
  • Views Views 4820
arymanx
Bedfordshire
I recreated a few brackets for Amiga 3000D, which seem to be desired by Amiga 3000D owners.
All this was possible thanks to my friend Niezgodka who kindly sent the original brackets to me for measuring.
The original brackets and the replicas are now in transit back to Niezgodka for final fitting tests (I do not own Amiga 3000D).
I made a small initial batch (10pcs of each bracket) and a few pieces of each are already promised to my close friends.
At this moment I have 5 of each available. I can produce more if required.
You can declare interest, but I am not going to send it until I get confirmation from my friend that it fits fine.
I made small mistake with HDD bracket (too small distance between holes, please see pictures).
This part will be supplied with manually rectified holes.
I will correct it in next batch if I will do another one. It is fixed now.
Prices:
FDD Type 1 - 16GBP (sold out, I do not have plan to produce more)
FDD Type 2 - 19GBP (a few available)
HDD bracket - 22GBP (a few available)
Zorro/PCI holder - 25GBP (a few available)
Main tray (new item) - 60GBP (sold out, I do not have plan to produce more)
Edit
Material: stainless steel 1mm
Can post worldwide, postage will be quoted individually.
FDD Type 1
FDD Type 2
HDD bracket
Zorro/PCI holder
There are two slightly different types of this bracket.
I am not certain that the position of the second hole is correct as the measurements were given by somebody else.
In my replica the marked opening is slightly thinner than in the original as it was not possible to fold the metal so close to the edge.
Main tray (made on request and with cooperation of kavanoz , original part supplied by trixster for measurements)
More pictures
here
For one of each part, total of 4 parts
(Marked as sold/completed by arymanx)
I’m almost sure I need one of each, but I’m not sure what the difference between the two types of FDD bracket are.
Edit: I get it now. One of each please!
I'll need a HDD bracket and one floppy bracket. Which type (FDD 1 or 2) I need, I am not sure of! Please help me with that decision.
Also, if you sell the A4000D PSU bracket, I would be interested in buying and combining shipping to the States!
Not sure if I can help with decision. As I stated in my post I do not own A3000D. I think it depends what type of FDD (slim or thick) you have.
Typ 2 can be also used with some old SCSI hard drives.
2 SFX brackets for A4k still available. Please declare interest here: link
Interested in 1 of each bracket - 4 total brackets
Declaring interest:
1 x FDD Typ 1
2 x FDD Typ 2
1 x HDD bracket
Declaring interest In the following:
2x FDD Typ 1 - 16GBP
2x FDD Typ 2 - 19GBP
2x HDD bracket - 22GBP
Next in line.
One of each bit, total of 4 parts total
1x FDD Type 1
1x HDD Bracket
Interested in an HDD bracket.
Declaring interest. Zorro/PCI holder x1
Declaring interest in
2x FDD type I
1x HDD Bracket
1x Zorro/PCI
PM sent.
Zorro/PCI holder x1
"There are two slightly different types of this bracket.
I am not certain that the position of the second hole is correct as the measurements were given by somebody else."
Will you put a thread insert in the second hole? At least in my A3000 this hole is used and threaded.
I'm happy to report, that all received parts are 100% interchangeable with originals. Everything fits perfectly, the only difference is the quality, that is superior to original ones.
Thank You again Szymon and great job!
Interested in an HDD bracket. Will send a PM shortly
(Interest withdrawn here)
Zorro/PCI holder x1
  1. kavanoz
  2. captainmoomoo
  3. tiim
  4. AmigaDigital
  5. Dale423
  6. RKolodziej
  7. DocLeisure
  8. blindguy
  9. steveed
  10. SukkoPera
  11. PrzemasIII
  12. StanMoonie
  13. saft6luck
  14. Dano
  15. Jens
  16. bax
  17. Ollis
  18. dwainwr
  19. Svenson
  20. Smithk4
  21. wildcopper
  22. Dale423
  23. Karlosjackel
  24. Ollis
  25. RoboComputer
  26. AwakeningStar
  27. dadstoy
  28. dadstoy
  29. jarema
  30. WarpedDimension
