Closed Broken external disk drive so I can put my Gotek in it
  • Thread starter Thread starter Sardine
  • Replies Replies 4
  • Views Views 485
Sardine
Staff member
Staff Moderator
Donator
Merseyside
As title looking for an external disk drive broken or just the case / pcb so I can put my Gotek in it
thanks
as usual I gave about 6 of these away a few years ago.... I should horde more and not give away :)
Have you ever considered using your Gotek bare, i.e. without any external casing?
I like mine better that way, especially with the round cable from a.mi.goun. My Gotek is black and it came with Amiga stickers on the front and on top. All I have added is a Gotek sized 4mm aluminium baseplate and 4 rubber feet, to give it some more weight.
When I got the round cable, I was surprised that no extra hardware was needed. After all, I've never seen an external Amiga drive without at least an extra PCB with a couple of ICs of some sort. Apparently the Gotek doesn't need any.
That's what I thought too, so I opened up the 23-pin connector cover and there was nothing inside :o
