C128 power supply rebuild (replica) kit with MOSFET power supply! You can use the psu for C128, C64 or Plus/4!
The legendary Commodore 128 psu rebulid now here! Removed the silly zener diode from the end of the circuit and replaced with professional mosfet saver circuit (same as the TinySAV64). It's based on the IRF9332 - as always.
Made from high quality parts, like Panasonic and Rubycon capcitors, Molex connectors. Psu can stable 2,5A on time. Added a led connector to the board, harness included to the kit. Also a new silver badge added, take a look
WARNING! You must have averange soldering skills to complete the kit and of course you need a halted (or working) C128 psu and a psu housing... Some piece of parts needed to solder to the new board from your old psu mainboard:
That's all! You can solder last time your cable with din connector depends what type of use: C128, C64 or Plus/4, you're choice!
100% handmade items. Please note: only the kit contains this listing, the old C128 brick psu only shot for purpose and can see the finishing product.
C128 power supply rebuild kit price: €54.9 (was €64.9) (+shipping)
Three pieces in stick now, can build more if needed.
If you don't have soldering skills or you scray with the 230V, never mind, drop a pm me, can finish your board by me for less!
- main transformer
- high current capacitors (two pieces) from the input line
- big filter coil
- filter coil from the input line
