Closed C64 Power supply 5V 3A, 9V AC 1.1A (plus/4 and C128 capable)
  • Thread starter Thread starter Raf
  • Replies Replies 3
  • Views Views 1765
Raf
Rating - 0%
0   0   0
Poland
Silesia / Katowice
POWER SUPPLY:
INPUT: 230V 50HZ FUSED
OUTPUT: 5V DC 3A, 9V AC 1.1A
WEIGHT: 0.75KG
Plug as on photo. Due to fixed transformer this can work on 230V/50Hz only, however making supplies with different plugs and transformers is possible if there will be demand for another batch.
Price is 40€
Shipping of one unit in EU is circa 15€ and 18€ for two (negotiatable).
I accept paypal and bank transfer (you pay fees)
Transformer itself is epoxy isolated and capped, contains integrated fuse and is soldered to PCB designed by me. There is fuse common for both transformer and SMPS.
Secondary side of AC is just like original supply (you have fuse in your commie) but unlike original unit this supply is fully repairable.
Moreover that switching supply has got protection on its own (short circuit, over voltage, over current) so you don't need to use these savers (you don't use 30 years old tires in your 30+ years old car, because they're original, right?)
This is just a power supply that I'd like to have, one unit capable of C64 and flat C128 as well and I'm happy to share it with others.
Unfortunately I don't have these dedicated rectangular plugs :) so you need to craft some kind of adapter for 128 or +4 yourself because so far I don't have one that is professional enough to share. I can only tell you, that there is circular din plug, that can be modified to fit socket in flat C128 perfectly ;)
Some information regarding prototyping stage can be found here: http://www.lemon64.com/forum/viewtopic.php?t=63997
I have just few pieces left. These have got higher quality NOS Polish made plugs (Unitra) - which were made 25+ years ago and there will never ever be more of them as Unitra vanished with Eastern Bloc fall, I just managed to acquire some.
Moreover there is possibility to send just one of these supplies as registered letter which makes transport more cost effective (35PLN~8.5€ instead of ~14€)
