Closed c64dtv PAL revision 2 or 3 wanted
torusam
united states
washington
Hello,
i am searching for a C64dtv ( also known as c64 direct to tv) revision 2 or better.
It must work, the box is not needed.
Shipment to italy is required.
Thanks,
Greetings,
torusam
torusam
united states
washington
Hi, i may be able to help, exactly how can I confirm the version to you?
hello,
the version 2 should contain a flash memory, it is built after 2005, and should contain Alleykat in the list of the games.
Also, if you have the box, the first version box is pyramid-like, while the others are not.
Greetings
torusam
