can a GBAPII++ connect to Indivision AGA MK3 ?
  • Thread starter Thread starter dempsey
  • Replies Replies 6
  • Views Views 451
dempsey
Denmark
Copenhagen
I know, its possible to connect a GBAii++ RTG card to a Multifix-AGA flickerfixer, like in the picture below, but is it also possible to do this using an Indivision AGA MK3 and if so how? - there seems to be an input missing on the MK3?
GBAPII++ has passtrough and does RTG/native 15kHz switching, not indivision!
problem is, my regular TV doesn't handle 15 kHz... so that's why I was wondering about the MK3 which is in stock at Indivision, whereas the Multifix AGA seems a bit hard to come by.
This is where a RATTE monitor switcher comes in. 2 becomes one with the SwitchControl software in your startup sequence.
There are sellers in here who sell the RATTE and cables needed.
@highpuff sells these
I have had no issues routing the VGA out on an Indivision AGA through the external pass through on the GBAPII+. All you need is a short VGA cable to connect the output of the Indivisiom to the pass through on the GBAPII+
In fact you can do this also internally if you have the Right cable
You need only a short VGA cable MALE-MALE from output of deinterlacer card to input of GBA.
