CF card hard drive shows as 2 devices
  • Thread starter Thread starter j_l_a
  • Replies Replies 22
  • Views Views 5588
OK, card has been to ChrisUnion, he kindly confirmed the card works. I got the card back this weekend.
Card does not work for me. I get the HD light for about 10 seconds then a blank screen and no activity. I have a feeling it's a PAL/NTSC issue. I've tried booting in both modes, and I'm not sure if the NTSC A1200s are identical and just default to a different mode, or if there are actual differences. Anyway, bottom line, the CF card that works in ChrisUnion's A1200 does not work in mine. I have another HD that will boot my A1200.
So I guess the next step is find a US specific A1200 and see if that works. :dry:
That's just strange because both the 1200s I tried are pal
units from the UK I just preboot and use ntsc and the 600
I tried is a ntsc so i'm not sure what the problem is I do
know it takes a bit of time to boot I would say over a min.
James try using the composite output and see what happens..
Did Chris test just the CF card or the card and the adapter/cable?
