Sold Checkmate 1500 Plus case in white, Amiga 500 rear panel, original box, 300W PSU, USB keyboard adapter and rear mount
  • Thread starter Thread starter gurthuk
  • Replies Replies 11
  • Views Views 530
gurthuk
Todmorden, West Yorkshire
I've decided to part with my Checkmate 1500 Plus case, in white.
I can't bring myself to throw my old A500 case away so I've decide to revert back and transplant my A500 motherboard across and have my accelerator hanging off the side like the good old days.
I bought this new in 2019 and it has been a great case. Included in the sale are the following:
  • floppy drive facia in white (left in place)
  • white facia for gotek (left in place)
  • white blanking panel (never used)
  • white lower grill panel that sits beneath the drives at the front so you can mount SD or USB ports (new in box never used)
  • long floppy drive cable, needed if you want to put an A500 motherboard in
  • long floppy power cable, needed if you want to put an A500 motherboard in
  • 3D printed mount for gotek sledge
  • 3D printed rear mount for SD card reader and RJ45 connector
  • original manual
  • original case stickers, 2 to choose from
  • 300W PSU (works with the switch on the front)
  • internal white LEDs that power off a spare molex connector
  • thumb screws on the rear to remove the cover, easier than the originally provided screws
  • internal card connect board
    • takes the ATX PSU and powers the A500
    • gives you a Zorro II internally
    • turns the A500 edge connector 180 degrees, I had my ACA500Plus mounted to this internally
  • A500 USB keyboard adaptor
    • dual USB cable to externally mounted USB port on the back (only one works with the adaptor - blue sticker on that port)
    • I'll throw in the matching PC keyboard
  • original box and packaging
I have left the mounts and stand-offs in place for a A500 motherboard.
Asking £200 including postage and packaging (in the UK). Outside of the UK p&p would be additional.
Edit: Item packaged and posted. Images of the packaging, receipt and tracking number provided.
