so,lets start with the warning.
#WARNING# these sets hold massive electrical charge even after its been off for ages,so if you feel the need to fix one of these make sure the screen is discharged BEFORE working on the monitor.
now that is out of the way,let me say this is not meant to be a walthrough or how to repair these,its just what i did to fix one i had.
so..lets begin.
first i removed the faulty LOPT.and cleared the solder points ready for the new one.and replaced all transistors in the area even if they have not failed.including thermal grease.
here is the offending part,ready for the bin.
next,i removed and cleaned the sticking mains switch and cleaned it with switch cleaner and greased the innards ready to be installed...
and re-installed the switch and replaced more transistors and regulators in that area.
then i opened this
then installed it.
and the two wires from the LOPT to the tube neck pcb.
at this point i tuned the screen and focus pots on the LOPT as they are set to minimum at the factory,and all is well.as in WORKING as it should
after setting all this up its time to discharge the screen and dissasemble the monitor one last time for chroma/luma to be added...
more to come...
so..lets begin.
then i opened this
then installed it.
more to come...
