Commodore Amiga 1200 with ACA1233n and Indivision AGA MK3.
Due to overcompletion, I am offering the following Commodore Amiga 1200 for sale.
- Commodore Amiga 1200
- A1200.net white (original) case
- A1200.net keycaps set US layout
- Kickstart 3.1 (v40.68)
- Revision 2B
- New capacitors (recapped)
- Panasonic JU253 Floppy Disk Drive
- iComp ACA1233n 42MHz 030 CPU with 128Mb RAM and MMU
- iComp Indivision AGA MK3
- Retro Ready Real-Time-Clock module
- Hitachi 4GB Microdrive
- Centuriontech LED-module
- AMIGAstore Keyboard membrane
- Centuriontech rear panel IO shield
It has a powerful ACA1233n accelerator, a must-have for WHDLoad. The PCMCIA slot also works, so it you can very easily add programs and software on the CompactFlash using a PCMCIA adapter.
The Amiga obviously works absolutely perfectly. All capacitors on the motherboard were proactively replaced (recapped), a top working system that you will not have to worry about for many years to come. This Amiga 1200 really is as good as new.
Inside the Amiga I have placed a Indivsion AGA MK3. With this you can connect the Amiga 1200 to modern screens (such as e.g. your TV) with HDMI and use high resolutions. The HDMI connection is beautifully concealed at the rear.
The original RF shield has been removed. In its place is a solid (0.8mm) stainless steel panel mounted from Centuriontech that holds the motherboard firmly in place in the case.
If you want a perfect looking and working Amiga 1200 and relive the days of yesteryear then you want this one! From a smoke free and pet free home.
Asking € 999 + Paypal fees includes free shipping world wide.
It will be shipped via a signed for and insured courier service.
- Revision 2B
