Closed Commodore CN2 tape unit with adjust display...!
tabuhuso
TURKEY
Adana
Head adjust very simple for you.
Loading error is over....! Adding REC light+sound buzzer...
I'm asking 10 £ + shipping
http://www.vimeo.com/4727076
cebd5f76896043
cebd5f76896043
cosmicfrog
The 1 That Ribbits
Rating - 98.8%
81   1   0
Leek, Staffordshire Moorlands
*eBay link removed*
Merlin
Manchester
I'm intrigued as to how this works. I wouldn't mind a similar unit, but a standalone plug-and-socket design, that you could plug in between the Datasette and the C64, so that you could use it as a service tool, to adjust the tape azimuth and optimise the signal strength on Datasettes.
I reckon that Tabuhuso's unit is probably taking the tape signal after it's been through the the op-amps, then feeds it into the piezo speaker and the meter in a series circuit, using a variable resistor to balance the deflection of the meter. The output from the meter goes back to the Datasette connector to complete the circuit. If anyone else could comment on how this might work, I'm interested.
I have a scrap C2N I can hack apart for the male and female tape port connectors, so I'll look to pick up some parts for a play around on some veroboard.
Comments, anyone?
cosmicfrog
The 1 That Ribbits
Rating - 98.8%
81   1   0
can I have confirmation of the rules plz then
you can sell items on here as long as you don`t say they are on the otherplace ???
edit:
ok forget that
me bad, just reread rules, again, probably wont be for the last time ether
cheeba
Ireland
Donegal
Definitely interested in this, is it still available? How much would postage to Ireland be?
Edit: I'll have to withdraw interest, as I since acquired a datassette elsewhere.
