Converting Amiga 500 to Amiga 500+
The Khemist
Midlands
Hi All
After rescuing some Amiga 1 x 500 and 2 x 500+. 500 is fine. one 500+ no battery leeks at all lucky :roll: battery removed now. Can not say the same for one of the 500+ had major battery leek. :mad:
Had acid all over U12 & U13 all over the audio filter and crept all over the resistors below Gary. I cleaned the lemon juice and IPA to not avail just green screen on boot! :(
So the question is can I move the chips from the dead board to the 500 and convert it to 500+? :dry:
Or is that blasphemy? lol
Tia
The Khemist (Dave)
Zetr0
Ya' Like it Retr0?
@TheKhemist
in short - kinda =)
all the chips are interchangeable except the 8375 - 3190544-xx Agnus
The Agnus from the A500+ is pin-incompatable with the agnus socket of the A500, however you can build an adapter board - (you would need to know how to make pcbs etc)
The better idea would be to see if the chips on the A500+ once replaced allow it to boot.
remember that the A500 and A500+ have different Agnii which are pin-incompatible - if you plug an agnus from an A500 into an A500+ or vice versa you will blow them up.
so instead try using the other chips (Paula, Denise, Gary and the CIA's Odd and Even) from the A500 into the A500+.
Remember to clean the sockets of the chips as well - I would suggest an electric toothbrush -
hope that lots help, remember take pic's =)
The Khemist
Midlands
Hi Zetr0
Just getting pack in to soldering been awhile lol. as for making PCB's one day eheheh.
The 500+ board that is damaged is in a bad way, looks like most of the tracks have been dissolved tbh. (n) I would take a Pic but my girlfriend has my camera and she is away for another month so. Need to borrow a cam from a friend. When I have some Pic i will post them.
Suppose there is a chance the 500+ board can be repaired have to wait and see I guess.
Thanks for you advice maybe best to leave the 500 as it is. :)
@TheKhemist
in short - kinda =)
AndyLandy
Acceleration!
Treasurer
Southampton
What revision motherboard is your A500? If it's an 8a, you're in serious luck, since that's just an A500+ in disguise!
Swap in the Denise and Kickstart from the dead Plus and you're away.
If your A500 is an r6, you can do the 1MB Chip RAM hack, detailed elsewhere on this forum. Swap in Denise and Kickstart and you've got a Nearly-A500-Plus.
Good luck!
The only A500 that can be upgraded to 500+ is the one with motherboard revision 8A (and 8A1, which is practically the same board).
In fact, that version is a crippled 500+ lacking a TTL chip for mux/demux the on-board RAM, four memory chips (4x256k) and the time circuit (not you'll want to stick a battery in there!).
The Denise ECS from A500+ can be used in any A500 or A2000 board without problems.
So, all chips from A500+ are equal to other A500 versions, but Agnus & Denise.
Grabbing a 8A1 board revision is hard, anyway.:(
Cloudane
Cumbria
In the style of @VizTopTips
AMIGA OWNERS - turn your A500 into an A500+ by simply pouring acid all over the motherboard.
No, but I strongly advice to all Atari users to do that to their computers(?).:twisted:
