Converting NTSC A1000 to UK A1000
SJBUK
Uk
Hertfordshire
I'm in the process of buying a US A1000 which I intend to use with a step-down transformer and TFT screen via some sort of scaler/scandoubler.
Over time, though, I'd like to convert it to a UK PAL machine just for the hell of it. I know I'll need a UK PSU and an 8371 Agnus and probably have to change the crystal. I've had a google about but not come across anyone trying it before. Anyone here got any opinions?
Steve
Harrison
West Sussex
Re: Converting NTSC A1000 to UK A1000
I've not heard of anyone converting an Amiga from NTSC to PAL before. Is that the only requirement to convert it? I would have thought there was more to it than that. Obviously you know that if you do manage to convert it, the CPU will be slower?
Justin
50 Hz PAL and 60 Hz NTSC TV output by default versions available
* 50/60Hz mode switchable by software, although switching a PAL Amiga to NTSC mode produces a 60Hz PAL display, and vice versa (this would usually suffice for software relying on a particular format)
tbh i would have thought buying a uk A1000 would be easy and not too expensive, they don't seem to go for much money at the moment.
cheers, JuvUK
Zetr0
Ya' Like it Retr0?
SJBUK
by far the easiest method would be to use a PAL A520 from the Video port :) job done no need to do anything else.
although you could replace
the Agnus to 8371 PAL,
the 3.58 colour ouput clock to 4.43
that would do it, I will hit up the specs later :)
I think you also need to modify a pair of traces on Agnus (need swapping 8361 to 8367) and on the video encoder, IIRC.
I think Daphne (pre-Denise) don't need changing.
SJBUK
Uk
Hertfordshire
@Harrison
Aye, I know i may be tad slower but it shouldn't matter for my purposes.
@JuvUK
I've not seen a UK A1000 going for a long time, one of the reasons I had a hunt around the other day and, luckily, found this forum. I've seen a couple on eBay over the last year or so but they've gone for silly prices. I may just have been unlucky and misssed some bargains.
@rkauer Zetr0
Cheers guys, the more info I can get the better :)
Might be nice, just for once, if I can do something few others have!
m0c
Cracked by Megabyte
Netherlands
Utrecht
Digging deep here... I converted my NTSC A1000 to PAL 34 years ago. As far as I can remember, it was a matter of replacing the 8361 Agnus by an 8367 and changing the oscillator block inside the shielded case from 28.636MHz to 28.375MHz. Exchanging the power supply won't make a difference other than the input voltage. The 50/60Hz tick signal is being derived from the mains power and thus depends on where the computer is plugged in.
I also recall adding a tiny PCB inside the shielded box at some stage, but I think it was only needed to get a certain PAL genlock working properly. I spotted the same PCB on eBay a few months ago, but can't find it anymore. I think it contained an MC1377 (RGB to PAL/NTSC encoder).
