CPC 6128 - How to make Reset & Pause switches
merlinkv
Ukraine
Kyiv
Hello my friends.
I'm involved with my CPC 6128 project and I need to know how to make two switches: one for Reset and other to Pause the system.
Thanks in advance :)
roy_bates
resistance is futile!
england
birmingham
first locate and identify the expansion port..pin 1 is the top side far right as you look into the back of the expansion connector.
for reset you need a momentary push to make switch wired between pins 40 and 49 or 2, 49 and 2 are ground 40 is bus reset...
for a pause or freeze switch,you need a latching push to make or toggle switch wired to 39 and 49 or 2.
if your doing this internally try to use a point further back inside the machine on the motherboard so you can still use the expansion slot.
it would be easy to do with a multimeter to trace them back further into the machine...
if you get stuck ill post a picture of the expansion port pinout if you like.
basically you need two switches and three pieces of wire,and thats it.
important: bare in mind the pinout is alternating between the upper and lower pins as its read from right to left...so be careful mate:)
if this is incorrect in any way whatsoever someone please feel free to correct me:)
merlinkv
Ukraine
Kyiv
Hello again :)
A bit late ..... but I have made all jobs for Pause & Reset Switch. I can't find small switches here, but looks fine:
Locating points 39, 40 & 49..... soldering cables & connector (before closing the case, I have used hot glue to prevent short-circuits):
Buttons/Switches in the case: Pause, ROM selector & Reset (from left to right).
Connections:
The back:
And ... I can't resist :D My new rework station: Aoyue Int 2738A+
All tested and everything works fine.
Thanks a lot Roy (y)
