For Sale Custom made case for Amiga 3000D - pre order
  • Thread starter Thread starter arymanx
  • Views Views 416
arymanx
Bedfordshire
Some time ago I created a case for A3000D for my friend. Now I redesigned it and decided to offer it to wider group. Due to limited time, I can not produce more than 5-10 pcs per batch.
I can post worldwide, but reserve right to refuse to post to certain countries. Cost of postage to Australia is around 100-150GBP, USA around 75-100GBP plus 25GBP packaging (I make "wooden" boxes for shipping).
Cost per case is 370GBP plus P&P. A pre-payment of 150GBP is required before I order laser cutting. Pre-payment is not refundable once a laser cut order is placed.
Cases are made from mild steel and powder coated RAL9005 ripple/textured (black). Zorro/PCI holder made of stainless still (not powder coated).
You will get an empty case with the required screws, brackets, and some 3d printed items/brackets as seen on pictures. Two DB9 extension cables, din5 extension, one FDD extension cable and two blue FDD power splitter boards are included. Fans, PSU adapter board with TICK, SFX PSU , RJ45/HDMI panel couplers and other cables are NOT INCLUDED. If unsure please ask.
PSU adapter board available at additional cost 25GBP.
RJ45/HDMI panel couplers available at additional cost 4GBP each.
Two units are available straightaway.
Please check link with more detailed pictures. Lots of improvements regarding ventilation, two side fans (one 70mm, second 92mm), 3rd (92mm) fan can be installed above CPU card.
