CV64 card restoration
salaxi54
Incoming ASROC!
GREECE
Athens
G'day to all of you! As promised, i have started this thread concerning the CV64/3D card i got from Chiark recently. Here's some pics for starters. It appears the readings i got with the multimeter on the traces are ok. The problem seems to lie on the alkali concentrated around most of the components of the board..
Fishin' chips? :D
Yet more of that..
Here's the trace that was suspect but continuity reads ok. Observe the chips pins underneath it. White residue everywhere..
Any suggestions as to which solvent is best suited for this job? I was thinking of doing a good clean, and once the card works(?) do the laquer thing.
Here's one i found earlier: http://www.surclean.co.uk/product.aspx?id=177&catid=2
Merlin
Manchester
Zetr0 swears by car screenwash with a toothbrush and it really gets the crud off.
I recommend that you neutralise the alkaline deposits with a weak solution of lemon juice or vinegar first though.
salaxi54
Incoming ASROC!
GREECE
Athens
Thanks Merlin, will do. Luckily our lemon trees still have lemons :D
A good bath a recipient containing IPA (isoprolyc alcohol) will do, too.
That white "gunk" is battery leakage that goes up to the board as fumes. Or other kind of air pollution.
jvdbossc
HypnusBE
Belgium
Antwerp (province)
Sorry for the little hijack, but is it safe to use any product like vinager, the car window anti freeze stuff, whater with lemon acid, on working boards?? (i have a board that has realy nasty sticky dust on it..)
AndyLandy
Acceleration!
Treasurer
Southampton
For that, I'd go with the IPA option first. I've cleaned loads of stuff with IPA and a paintbrush and been very successful :)
salaxi54
Incoming ASROC!
GREECE
Athens
Ok, here's what i did: 1st, i made a solution of 1/4 lemon juice and 3/4 distilled water. Good stir, then applied with a used toothbrush (yummy! :D )
After drying in sunlight, i applied some IPA again with the toothbrush. Most residue was removed. Second drying, then finally applied distilled water only. It looks clean... Although i let it dry again in sunlight, just to make sure i gave it a shot with a hair dryer (cool air). This is an aftershot
Now, for the RTG experts! Well, i really wanna know first of all, what can go wrong if i install it in the Draco. Reason i'm asking is that there's already an Altair, the Kasmin, and the CV would be third up. :)
Would it affect the system in anything? And what would the Autoconfig ID be by the way? Is it possible that i might see anything if i plug a monitor on it from the beginning, or would i still have to do the installation in order to get any picture?
Merlin
Manchester
@ Jurgen
"Science Bit" warning.....:readit:
Citric Acid (the main thing in lemon juice) is used extensively in the engineering industry as a metal brightener, particularly for aluminium alloys. I saw it being used to clean Magnox magnesium/aluminium alloy nuclear fuel cans at BNFL and they came out super shiny :cool:. It's also a weak acid, so it's highly unlikely to etch into the tracks to any degree. Acetic Acid (vinegar) is similar.
(y)
salaxi54
Incoming ASROC!
GREECE
Athens
Had a go on the Draco today, it's a "no-go" still..
I even removed the Kasmin, same thing. Then, i removed the Altair and left the CV alone in there. Still nothing. I was hoping to at least have a report of the Autoconfig in the early startup menu, not necessarily getting a picture from the CV itself. I'll try to repeat the cleaning process tomorrow utilizing vinegar this time. If still nothing happens, i'll have a check on the oscillator.
But first, i'll give it a check by plugging it to the Panzer-tower A2000 :)
Cosmos
France
Besançon
Why using distilled water ?
Zetr0
Ya' Like it Retr0?
@Salaxi
my friend, I would look to replacing the Xtal on the card, see if that makes any difference.
Normally if the card fales post then theres a RED screen, However if you are not getting even that its likely the card is inert, hence the pump (xtal) is suspect.
salaxi54
Incoming ASROC!
GREECE
Athens
@Cosmos: Well, maybe distilled isn't the correct word for it, but i think that's what it's called? It's actually the kind you would use for electric irons (the one for cleaning salt crystals from the orifices of an iron)..
Thought it would be better thanregular tap water.
@Z: I was just thinking of that, and have some questions about the xtal! The onboard is an 50 Mhz one. Has 4 pins. Searched the evil bay and although the ones i found looked very similar, the description would mention 8-pin! Is it some naming trick? By the way, i plugged the card in my "Panzer" A2000 tower, and nothing showed up there either..
mfilos
Extr3m3ly l33t
Glyfada/Athens
I have a spare "full can" 50MHz oscillator (i think it's compatible with the "half can" that Keith posted) that I bought some time ago from Futurlec for my Apollo 630. Call me if you need it man :)
salaxi54
Incoming ASROC!
GREECE
Athens
@Zetr0, @mfilos : Thank you both for your replies! Z, that's what i'm talking about, haven't been involved in anything to do with crystals except for my RC models rarely. That there ad still mentions something about 8-pin stuff, and i find it confusing. Physically they look correct. Is that how the 4 pins are measured? (says something about pins 1, 4, 5, and 8...
Mario, thanks for the offer my friend, will let you know if i don't come up with the ideal one (y)
matt020
Finger lickin' good
Western Australia
Yo.
I was going through some old posts and came across this one. Did you end up getting the card working??
Matt.
chiark
AmiNerd
Yorkshire
Yo.
Matt.
Indeed, I'd be intrigued to know :D
I tried cleaning with isopropyl myself but obviously didn't use enough! the xtal was mentioned before as likely culprit...
salaxi54
Incoming ASROC!
GREECE
Athens
Well, at long last, after a very long crystal-searching adventure, i got it yesterday! Here's the progress so far:
PCB after the oscillator was removed
New oscillator in place!
Bottom of PCB
A good cleanup, and tonight's the night for a test drive! Wish me luck folks..:)
