Request Cyberstorm MK II which boots - no zorro slots
pvanb
Canada
alberta
I have a Cyberstorm MK II which boots from A4000 IDE, runs programs no problem, recognizes the onboard ram, but does not recognize boards in the Zorro slots.
I was only able to test with 2 scsi controllers cards....a 2091 and a GVP 4008. Both boot their HD's with 030 cpu card and a 3640 cpu card, but not with the MK II.
The bottom Zorro slot, video I believe, has a 2320 de-interlacer card, which works with the MK II and the other cpu boards just fine.
I have tried the MK II Update unsuccessfully.
It seems the firmware is corrupt, but only for the scsi/zorro recognition.
Is it possible to re-flash the firmware?
Regards,
Peter
Xanxi
France
Paris
Could it be a fault with the Buster instead if the problem is autoconfig of Zorro slot?
I suppose your are not using the Cybertsorm SCSI addon?
pvanb
Canada
alberta
No I do not think so, as I have tried two different CS MK II 060 boards and they both work perfectly in this 4000.
One had the SCSI addon.
I have sold both and in the process of selling this as probably for "parts or repair".....but likely unfixable.
Thanks for the reply,
Regards,
Peter
