.d64 to disk
jimbob005
swadlincote,uk
swadlincote
hi there
is there any one in the uk able to convert .d64 back to disk ??
i would like to put a demo on to disk if any one can help me i have disks and the .d64 file
thanks james
sarek2k
Morecambe, UK
Lancashire
Re: .d64 to disk
@Jimbob005
I would say you stand more chance of gettting this done at http://www.lemon64.com/
some of us here have real c64's/disk drives and pc's but not a means to connect the two together (hope you have more luck at lemon64
Merlin
Manchester
Re: .d64 to disk
Hi James
You need one of the XA1541 adapters available via a certain auction site. These connect to the printer port on the PC and allow you to send files to a 1541 disk drive. There is also n XE1541 adapter but I am led to understand that the XA1541 is better.
I hope that this helps.
Merlin
jimbob005
swadlincote,uk
swadlincote
Re: .d64 to disk
@sarek2k
thats my problem i have a real c64 and the files on the pc. The pc emu is good but some times its nicer to see it running on the c64
@ Merlin
iv found an adapter i dont want to buy the wrong one its an xe+xm1541 ill post a link but if its agenst the rules i will edit it off i just dont want to get the wrong thing.
http://www.nkcelectronics.com/commodore ... a1541.html
thanks james
Merlin
Manchester
Re: .d64 to disk
Your link is fine James.
That is the type of adapter I was thinking of, however, I would advise that you talk to someone like Overdoc over at Lemon 64 forums, to make sure that you get the right one; some of them aren't compatible with more modern motherboards but I don't know which ones.
Cheers
Merlin
Harrison
West Sussex
Re: .d64 to disk
Personally I would recommend the Catweasel PCI controller card for the PC. This PCI card allows you to connect original C64 drives, as well as standard 3.5" and 5.25" drives, to a PC and read and write to C64, Amiga, ST, Arch and many other file formats.
It is quite expensive at £74.99, but it is strongly supported, with the developers releasing firmware updates regularly to add new features to the card and fix any bugs users report.
A member of classicamiga called Demon Cleaner owns one of these Catweasel controllers, so if you need to ask some questions before you look into buying one then I recommend you have a chat with him as he should be able to answer your questions. He is a C64 user so has used it to read and write C64 disk formats.
