dead PS2 keyboard controller
Station240
Adelaide,Australia
South Australia
Managed to get a loose rivet lodged on the motherboard of my one decent PC. Everything works except the keyboard, which is connected to the only PS2 socket on the board. I checked and the keyboard is getting power, no onboard fuses blown either.
While I couldn't trace where the PS2 port runs to, stupid 8 layer board, there is a chip on the board where the rivet was lodged, a 74HCT125.
The Super IO controller is a IT8720F, which is described as undocumented by the linux community, hence no datasheet anywhere.
Most likely its a damaged SMD 74HCT125, which is a quad tristate buffer. But while I can fix that, I have no idea about the rest of the circuit.
So my question is simple, is there a buffer chip used in the keyboard circuit of modern PCs or not ?
Station240
Adelaide,Australia
South Australia
Found a useless PS2 to comm port adapter and used it with my multimeter to trace where it goes. Pin 5 KBDClock connects to multiple pins on the 74HCT125.
Removing the old chip was easy enough, now to find where I can get a replacement SMD version. :coffee:
