Sold DELL 2001FP LCD Monitor - 1600x1200
  • Thread starter Thread starter crabfists
  • Replies Replies 12
  • Views Views 4704
crabfists
Warrington
I have a DELL 2001FP monitor in Black with a native resolution of 1600x1200, so is ideal for Picasso IV or Cybervision 64 or other gfx cards that run at 1600x1200.
It also supports 15khz and has a manufacture date of October 2004.
The non-widescreen aspect ratio is also ideal for any type of Amiga. Inputs are D-SUB , DVI-D (?), S-Video and composite.
It is a few years old now but still looks great considering. At the time it was one of the best looking monitors money could buy. It also has a pretty low refresh rate of 16ms, so is ideal for gaming.
The stand is height adjustable and it can be swivelled to work in vertical mode.
Price is £40. Shipping to the UK is £10. Payment by Paypal friends and family.
You should specify whether it can show 15.6kHz directly, or if you do not know, the manufacturing date since that is what most people here would be interested in. The DVI connector is also a hint since some have DVI-D and others DVI-I. You write DVI-D, but this could be a mistake if you just took it from the specs.
@demolition Good point. Thanks! Yes, it does support 15khz. Post edited to include that info.
Edit: removing the specs as I copied and pasted them from somewhere else so can't guarantee they match my monitor exactly.
Would it be possible to ship to Michigan, USA or is it only strictly the UK? If it can get sent to the USA, how much would it be for shipping and is it NTSC (60Hz and 100-120V) capable as well?
If definitley displays an amiga screen then i'm interested and could pick it up next saturday
Well, I have to admit that I used it with an A3000 which spits out 31khz via the D-Sub connector. I'm pretty sure I have plugged in 15khz composite and S-Video and it worked ok. Are you using composite or something else? You are free to bring your Amiga to try before you buy.
June 2005 and earlier panel revisions 'should' display an Amiga 15khz screen fine (both mine do), but be aware that you have to recentre the picture on each amiga power-on as the display does not save the Amiga's position. This is not as bad as it might seem as in the menu you only have to press up/down and left/right once each and the picture snaps into the correct position. The display will also handle Indivision AGA and AGA Mk2 50hz screen modes smoothly without stutter or smearing (i.e. it does 50hz fine). Similarly the svideo input does 50 and 60 hz scrolling perfectly smoothly too (good for modded c64, CPC etc).
I'll take if its available then, send me your details and i'll PP the money straight away.
