Sold Dell Ultrasharp U2410 - Multisync monitor
  • Thread starter Thread starter Jamie
  • Replies Replies 5
  • Views Views 651
Jamie
Stourbridge, West Midlands
[FONT=&quot]Dell Ultrasharp U2410 - 24" widescreen monitor
[/FONT]
[FONT=&quot]Syncs to 15Khz - so good for Amiga, Atari ST etc.[/FONT]
[FONT=&quot]Loads of connections,Display Port, DVI, VGA, Component, Composite.
[/FONT]
[FONT=&quot]Great condition - £75 collected from Stourbridge, West Midlands
[/FONT]
And just a tip if you're going to use it with a C64: While the picture quality is decent through S-Video, I found that it has a weird issue syncing to the C64's signal if you turn on the C64 after the monitor. As long as the C64 is connected and powered on while the monitor is switched on, it works fine even if the monitor is on a different input. As long as the monitor was turned on this way, you can power cycle the C64, disconnect it etc. and the issue won't appear again until the monitor is power cycled. So if you have problems with the C64 signal, just power cycle the monitor with the C64 turned on and it goes away. :)
Transaction completed; paid and picked up monitor in person - thank you! Positive feedback also left.
@Demolition - many thanks for that extra info! I have noticed a similar issue with another combination of monitor and console as well which needs exactly the same process, so what you said makes sense. Thanks for taking the time to advise!
