DKB 1202 Yellow screen
desantii
Chicago
Hi, I have a DKB 1202 ram expansion from the site but I am having problems with the FPU. With no FPU it works fine. When I plug and an FPU an oscillator (I have tried two FPUs and 4 oscillators) I get a yellow sceen and no boot. With no oscillator (FPU only) black screen and no boot
any thoughts
thanks
keropi
Ioannina
obviously there is some damage in the FPU-related circuity... is there any visible damage (like scratches in tracks etc)?
Justin
any use bud?
Amiga system will not boot. Screen flashes colors or keyboard lights flash.
You may notice that when you turn on or reset your Amiga a few different colors flash by. These actually mean something. Here you go:
Red Bad ROM
Yellow CPU Exception Before Bootstrap Code is Loaded
Green Bad Chip RAM or Agnus (check seating of Agnus)
Black No CPU
White Expansion passed
Grey CPU Passed
Constant white is failure of CPU.
Or as taken from the Amiga 4000 Service Manual:
Passed Test
Light Gray Initial hardware configuration tests passed.
Initial system software tests passed.
Final initialization test passed.
Failed Test
Red ROM Error - Reseat or replace
Green CHIP RAM error (reset AGNUS and re-test)
Blue Custom Chip(s) Error
Yellow 68000 detected error before software trapped it (GURU)
The system performs the following test sequence:
1.
1. Delays beginning the tests a fraction of a second to allow the hardware to stabilize.
2.
Jumps to ROM code in diagnostic card (if found)
3.
Disables and clears all DMA and interrupts.
4.
Turns on the screen.
5.
Checks the general hardware configuration.
If the screen remains a light gray colors and the tests continue, the hardware is OK.
If an error occurs, the system halts.
6.
Performs checksum test on ROMs.
If the system fails the ROM test, the screen display turns red and the system halts.
Keyboard
One Blink ROM Checksum failure
Two Blinks RAM test failed
Three Blinks Watchdog timer failed
Four Blinks A short exists between two row lines or one of the seven special keys (not implemented)
#related td {font: 8pt verdana,arial;padding-left:10px; text-indent:-10px}#related a,#related a:visited,a:active {color:#306;}
desantii
Chicago
I have not checked the keyboard lights, will do so. Board looks ok physically
thanks
Zetr0
Ya' Like it Retr0?
@desantii
Under Kickstart 2.04 and up, most of the error colour codes were scrapped and not implemented on the Amiga A1200 it uses Kickstart 3.0 and up, as such MOST codes mentioned are not a good enough indicator of what the error is.
To be honest, "RED = Hardware Assetion Failure" is the only garantee you have.
I have to admit I love this bit =)
Failed Test
Now, I have an A4000, and I will be damned if I can find that Agnus or that 68000 cpu.
The above only really applies to A500's and A2000's with Kickstarts under 2.04 otherwise most of the error colour codes you will get are a guestimate at best.
Now it would seem that you are suffering from FPU assertion failure, that is to say, you put it in and the system hangs, the question is - why?
the FPU is quite a transparent circuit to be honest, I am assuming you have the following card
Two FPU's and 4 Oscilators lends me to believe -
1. theres a fundamental fault with the card,
2. you have either the xtal or FPU inserted incorrectly
Lets take the easy one (number 2) and isolate that first
Next is a little more involved, so lets see what we got -
With the FPU installed and no Xtal in the socket the system wont boot:
As the FPU is not reporting, hence the black screen of nothing-ness: this is to be expected - even though there are two chips with different pathways (the FPU and the mobo based CPU) both of these are seen as one entitiy by the system - as such if the FPU doesn't work niether will the onbard CPU.
With any XTal installed the FPU an error screen is shown:
Now this can be a number of issues however we can rule out the following
1. it is not an FPU failure
2. it is not and XTal failure
so what can it be ?
Lets take a look at the mechanical,
1. Inspect the solder points of the Trapdoor connector, do any of them touch each other?
2. Inspect the FPU socket is it cracked or fractured in a corner?
3. Inspect the FPU socket Pins, are any of them crushed/crippled inward
4. Inspect the XTal socket - do all the XTal pins fit nice and snugly?
Thats just to begin with, hit that lot up and see how you get on =)
good luck
desantii
Chicago
Thanks Zetro! It is exactly that card
From the testing done its is definitely something with the card, it looks ok but I will have another look. I have tried with 2 FPUs and 3 oscillators so I guess that rules them out. I have also tried in another A1200 and same issue so not an A1200 issue
desantii
Chicago
Ok, so I cleaned it up and still nothing, all looks ok but same yellow screen so I am just declaring dead FPU hardware.
Cleaned up, inserted both FPU and Xtal = Yellos screen, constant reboot
Xtal and no FPu = normal boot
FPU and no Xtak = no boot, black screen
Same issues on difefrent FPUS, Xtals and another A1200
thanks everyone for your help
Kin Hell
U.K.
Cornwall
@ desantii
Did you buy this board via AmiBay as a fully working board?
If so, raise the matter accordingly. (y)
