Does WHDload throttle ?
bundyboy123
Victoria
I am using WHDload for games but getting slow down with 060.
The main game I notice it with is Last ninja 2.
Does WHDload throttle for compatibility to imitate 68000 ?
fitzsteve
Retired Slacker
Sevenoaks
There are a couple of things you can try for compatibility such as WHDLoad tooltypes, try cache and nocache see if either of those help.
Best cards for WHDload are the 030's ;)
demolition
Denmark
Copenhagen
AFAIK this is all up to the slave designer. It is quite common to insert blitter waits into games to improve compatibility with faster processors. But slave designers cannot test on all possible configurations, and it is not always easy to ensure compatibility across the board. Maybe it can be improved by changing the prefs of your WHDLoad, or you can file a bug report (of the slave), and hopefully someone will pick it up and make a fix.
