Elbox 1200 help
StrontiumDog
The Willen Lake
Can anybody tell me where on a Rev 1D4 A1200 mainboard I plug the reset connector to?
It's a standard 2pin connector connected to the reset switch on the case, but the only pins I can see to plug it onto are the 34 pin floppy (in use) or the clockport pins.
The Elbox webpage blurb says:
[FONT=Verdana, Arial, Helvetica, sans-serif]"a RESET button connected to the processor's RESET signal in the A1200 board"
[/FONT]
You can't see the pins for a reset switch because they are not there. There are two pads on the 1200 board which you can solder a switch/pins on to. The pads are below the PCMCIA port.
Ah-ha! muchos gracias Playgeneration
Onwards! out with the trusty soldering iron - there is hackery afoot! :)
copied from Aminet:
A1200-Board (view from the top)
| P |
| C |
| M |
| C |
| I |
| A |
| TP1
| |**********< 1
| TP2
| 1 >**********|
|O
You have to solder a 2-pin connector (like those on PC boards) to TP1 PIN 10 and PIN 9. The RESET switch of a standard PC tower can be connected to the above connector.
