We have gas central heating in the house but there are no radiators in the Kitchen. Not a problem when the oven is being used, but gets cold the rest of the time. It's a fairly big room at 15' x 8' so the cold air can create a draft into the rest of the house. It wouldn't be easy to get the central heating extended into there as there are no radiators near to the room and the pipework runs across the other side of the house.
Therefore I'm thinking a small wall mounted electric panel heater would work OK. I checked how much it would take to heat the room and the online calculators said for the size of room it would need a rating of 2182 BTU. Looking at radiators even a 700W radiator would be enough, which I was surprised at so shouldn't be too expensive to run.
After much looking I've found a Reina Arlec aluminium electric radiator which has a digital display with timer and remote control, and not a bad price. Has anyone used these? It looks nice and unobtrusive. Many of the others are quite ugly.
Can anyone recommend any other makes and models?
Ideally we want a remote control so we can set it via the remote mounted near the main house thermostat in the hall.
Alternatively we are interested in upgrading our main central heating thermostat and timer with a Hive one. This made me wonder if there are any electric wall heaters that could integrate into the Hive to make it a more seamless central control for both.
