Buy a small UV-C lamp (5W is enought) in a acquarium shop.
Use a neon circuit to light it on.
UV-C are dangerous never look into the light or expose your skin.
i would suggest this lamp: http://www.ebay.it/itm/ULTRAVIOLET-...84?pt=UK_Stamps_Philatley&hash=item54095ec280
it is on the same wavelength required for erasing eprom (254nm) 4w power.
be warned uv-c are dangerous i suggest to place the "eraser" into a shoe box and close it when lamp is on.
i created a wood box, inside is covered with alluminium foil. then i placed a microswitch so it does turn on only when the cover is closed.
i have built that in the far 90's and i still use it!
Agreed, as cheap as they are it's pointless to build your own. Plus there is the risk factor with a homemade job.
A bigger tray is about the only concession I would make to a higher priced model since occasionally I will update all of the firmware in a certain programmer at work, and that's 15 - 20 proms at a go. But this is such a rare event that even then it's doubtful it would be money well spent.
