Ive been toying with the idea of installing an optical drive into an A1200 for sometime now and finally decided to take the plunge. After much deliberation about how to set about it with drive position etc I decided to follow other peoples examples and place the drive pointing out the back near the lefthand corner.
To start with after a few test fits I decided to removed a few mms from the lip at the rear of the case along with a couple of latches with the results looking like this...
Having done this the drive door closes flush with the bottom edge of the case with the drive body resting on the trimmed ledge... There is a step in the case which is behind this. I will be filling in with a velcro strip that I am using to secure the drive.
Next I went on to cut out the slot into the upper half of the case.
This I did with a dremel type tool using a small toothed cutter.
Ive included a picture here showing the adapter Ive decided to use to convert to a standard IDE interface, I picked this up from Maplins this morning.
I couldnt make my mind up how to go about mounting the hard drive and 4 way interface due to space constraints and wishing to keep the the clockport clear for future expansion. I would of used a CF adapter but Ive had problems finding a CF card that doesnt leave a dull glow on the hard drive activity LED... all except a 256MB card which I use for PCMCIA transfers...
So I came upon the idea of using velcro to stick the drive to the top of the DVD drive... to allow extra clearance in the top part of the case I had to remove part of the top grill slats from the inside of the cover.
Heres a photo showing a test fitting of the drives...
And heres a second photo showing what is basicly everything connected up, only remains for the wiring to be tidied and the 4 way IDE adapter secured into position.
And lastly a photo showing the rear of the A1200 with the drive fixed in place.
