Fitzsteve’s Amiga Journey – Part 9
  • Replies Replies 18
  • Views Views 7885
fitzsteve
Retired Slacker
Assistant
Sevenoaks
Please see below links for parts 1-8 :ninja:
Part 5 Part 6 Part 7 Part 8
Retr0 Replay had been an awesome event, it was great to meet yet more awesome Amigans from the community.
Sadly over the course of the event my A4000 had developed a fault with the Scan Doubler on the PicassoIV so once home I stripped it down to fault find.
Whilst the A4000 was in bits I also decided it was time to try and do something about the Buster since I’d had further troubles installing an X-Surf network card, I was intending to use this at the event for some network play but it wasn’t meant to be.
This is what I had:
The Belkin Wifi adapter I hoped would connect this to my Wifi Network
As you can see I had no problem installing the card, but the Amiga just refused to boot with it in place.
As always lady luck was shining on me and I spotted an A4000 Motherboard and Elbox Tower on Amibay, the Motherboard was complete with Buster -11 and I also took the Tower as I got a deal on the pair.
Luckily I had enough spares in my box of bits to build this into a basic Amiga 4000 for testing; I had my spare A3630 that I took out of the A4000D when I upgraded to the Apollo 4040. I also had my old 3.0Roms and plenty of cable =D
I was actually very impressed with the Elbox Power Tower, it’s a very sturdy Tower and I like the way the side panel detaches for installation of the Motherboard/Busboard:
Now time to test out my Zorro cards that didn’t work with the A4000D along with a PicassoII I’d picked up.
Finally after having the Z3 Fastlane for several months I saw it work! Along with the X-Surf and to my surprise the Wifi adapter did a great job too!
Now I had to make a decision on where to take these projects, since the A4000D was back up and running, the Scan Doubler fault was cured by a new Daughter Board and it was back to full function as you read in Part 8 and to be honest I was very happy with it.
Being back up and running I was also reluctant to pull it apart and fit the new motherboard and then try to squeeze the Z3 Fastlane and X-Surf in, it was clear things would start to get very crowded in the little desktop case.
So, I done what all Amiga nut cases do, I started a new project! My A4000 Tower project was born!
First thing I done was source a new front for the case, borrowed from an A1200 Power Tower:
Here she is along side her little brother =D
Next thing’s sourced were an A3640 to give the old girl a boost! And some shiny new 16mb Simms for the Z3 Fastlane:
Whist she installed just fine I did have trouble getting all the Ram to be configured, to this day the best stable configuration I can achieve is 128mb, I’ve had it running at 192mb but it crashes and never quite got 256mb
I won’t bore you with the details here but there are some lengthy threads in Amioracle if you fancy a read!
For now the work stopped here because the A3640 was very unstable, I put up a wanted ad for repair and also upgrade to 33mhz, an awesome Amibay member d0pefish offered to take on the job and the A3640 was shipped off along with a nice shiny new 33mhz 040 chip for the work.
In the mean time I found a nice Cybervision 64/3D to replace the PicassoII, I was also lucky enough to find a Scan Doubler unit for it as well:
A3640 Upgrade
Upon receipt of the A3640 Dale tested and confirmed that there was indeed a problem and that it would only boot randomly.
We decided to replace the CPU for a 33mhz unit, replace the Caps and also fit a socket for the oscillator so that we could try to overclock to 33mhz.
The first of the parts arrived:
Next job was to replace the caps:
As you can see Dale identified and repaired the problem, one of the Caps had blown and damaged a track leading to the 040 CPU!
Dale didn’t stop here, he also re soldiered all two hundred pins on the CPU connector!
He found that the Gal chips were getting very hot and this caused the card to be unstable so also socked and replaced the Gals upgrading the A3640 to rev 3.2
Here is one of the suspect chips:
Removed and replaced with socketed chip:
Job done and now we have a fully stable 33mhz A3640 Rev 3.2!
I can’t thank Dale enough for taking on this job for me and the work he has done, with this at the heart the A4000 is very nippy indeed.
Here is a short video of it up and running:
So we’re almost there, just one chapter left to go! I hope you've enjoyed my story so far. I'll try not to keep you waiting too long for the final instalment...
Click here for Part 10
Hi Steve,
Looking your A4K's I'm...... :woot:
The Elbox Tower :thumbsup: is a dream for me... :)
Very, very nice setup :thumbsup:
All the best.
Hi Steve,
All the best.
Thanks Pablo! I'll make you deal, if I ever get a Mirage Pro this Tower is yours FOC :thumbsup:
Steve.
Hi m8,
Oh! Thanks but I think any day (year? :D) Mirage kit comes at home :D
One thing, do you consider to buy ZoRAM module/s for your setups. I ask because I see you don't use SCSI on Fastlane... or is to get more compatibility?
All the best :thumbsup:
Hi m8,
I'm keeping my fingers crossed for you mate!
I tried 3 SCSI HDD's and I couldn't get any to work, in fact I should have mentioned this in my story!
One day I'll try this again as the Z3 Fastlane will offer me a very fast option for data transfer, I think the adapters I bought were no good and this is why I couldn't get the drives going.
Its something for me to try in the future becuase now I don't intend to buy any more systems or make any further projects, just consolidate these ones. :)
Cheers!
Steve.
I understand you very well.
I have four Amiga's and don't want/need more. Just consolidate & finish well two of the projects I'm building now :coffee:.
Four systems for my Amiga's "fever" is enough :D
Best wishes
Just a little update, I've added links at the end of the first post for each Chapter, this means that it is possible to read back-to-back the story from the very first post just by following the links at the end of each part.
I've just read through and it took me a good half hour/40mins so make sure you have a cup or glass of your favourite drink should you decide to take the plunge!
:pint:
Cheers! :beer:
Steve, I hate you and I hate these threads... All they are doing is making me drool and alerting me to the existence of more and exciting shiny pieces of hardware. ;-)
Nah, seriously, I'm loving this pr0nfest. You've got some really sweet bits of kit there, my friend!
Hey Steve, as I'm planning for a summer trip in UK, what is your exact location of your house. Of course you will leave the house key under the doormat. :whistle:
Extremely nice hardware collection you have.:thumbsup:
In that case you're going to equally love and hate chapter 10 :D
But seriously, I appreciate the kind words and I'm really pleased you're enjoying the threads :thumbsup:
No. Ten Downing Street, London - You'll have to get past the Guards with funny hats though ;)
Thanks for the kind words by the way :)
Steve.
@Phantom
If you need I send you my old Black Beret suit ... Maybe this help to pass :D (is a joke)
I'll surely need this Invisible Cape from Harry Potter.:D
@Steve
Hi my friend.
Don't forget to publish part 10. I'm waiting that. :)
In my opinion, this multi-thread is one of the best here :thumbsup:
Best wishes
@Steve
Hi my friend.
Best wishes
He he, glad you like it my friend :thumbsup:
But its like a TV show, you have to wait til the next episode ;)
Steve.
These just keep getting better Steve mate! Super mad amount of hardcore circuit pr0n here! :drool: I especially like all the amazing work of d0pefish, flan flippin' tastic! :D
Thanks mate :thumbsup:
Was going to make you guys wait till next week for part 10 but I think ya'll need some pr0n for the weekend.
I'll see if I can roll it out before ;)
hehehe seemsds you have made a few ppl gelious steve
just a thought but can u do a list of the stuff you brought last year and a list of the stuff you sold plz plz plz with ribbits on
I still have mixed emotions when I see that budda ide card, was it the right thing to do etc, hehehehehe :thumbsup:
also wheres my mention of A3630 :coffee::p
Sorry mate, can't kiss and tell about all the kit thats passed through these grubbly little fingers :p
As for the buddha, yeah I feel pretty guilty about that still lol!
If I find one on ebay I'll snap it up for ya or if I replace with a FastATA then I'll return it to you ;)
Steve.
No worries
I`m over the ide card now, I have replacements :)
but its still a nice card
