For sale FOXCONN d41s MiniITX machine. Setup comes with Crucial Ballistix 2Gb ddr memory and WD Green 320Gb SATA2 hdd. Purchased last year with intention to hide in loft as wifi backup/server station but it never happened. Very compact computer with space for 3.5" driver and lowprofile card. Great as server or tv/internet box, motherboard can be moved to netbox case if needed.
It's nearly new setup, fans are still dust free, just few minor marks because of moving from place to place.
Full motherboard specs:
Processor Intel® AtomTM Single-core D410 processor mounted onboard
Chipset Intel® NM10
Front Side Bus
Memory DDR2 800/667 MHz x 2 DIMM, Max. 4GB
VGA on Die Integrated Intel® GMA 3150
Expansion Slots 1* PCI
IDE N/A
Serial ATA(SATA)/RAID 2* SATA II
Audio 5.1 channel HDA
LAN Gigabit LAN
IEEE1394 N/A
Back Panel I/O Ports 1 x PS/2 keyboard port
1 x PS/2 mouse port
1 x Serial port
1 x Parallel port
1 x Audio jack supports 3 jacks
4 x USB 2.0 ports
1 x RJ45 LAN port
1 x VGA port
Internal I/O Connectors 1 x ATX 24-pin power connector
1 x ATX 4-pin 12V power connector
2 x 4-pin CPU / System fan connectors
1 x IrDA header
1 x TPM header
1 x COM header
2 x USB 2.0 header supports additional 4 ports
2 x Serial ATAII connectors
1 x Front panel connector
1 x Front Audio header
1 x S/PDIF out header
1 x Buzzer
BIOS Features 8MB flash EEPROM w/ LAN boot PnP, ACPI, WfM, DMI 2.0
Support CD
Standards/Manageability PCI 2.3, USB2.0, DMI 2.5
Special Features
Form Factor Mini-ITX (6.75 inch x 6.75 inch)
PRICE: £42 + FREE UK POSTAGE
Chipset Intel® NM10
Front Side Bus
IDE N/A
LAN Gigabit LAN
IEEE1394 N/A
1 x PS/2 mouse port
1 x Serial port
1 x Parallel port
4 x USB 2.0 ports
1 x RJ45 LAN port
1 x VGA port
1 x IrDA header
1 x TPM header
1 x COM header
1 x Buzzer
Support CD
Special Features
