Taken Free memory!
Fizzy
South Wales
Ok, as part of the continuing clearout I thought I would make a dedicated thread for the memory I've found so far.
All 72 pin simms :-
15 x 16MB (all single sided). 2 are two chip, the rest 8 chip. All seem to be 60ns, although some are edo memory.
8 x 8MB (2 double sided, rest single) of mixed types.
1 x 4MB single sided.
Also have 3 x 32MB sodimms/sosimms? (kingston make, KTH-OB7100/32) which should work in older laptops or other board/devices that take 'em.
More pc related, but may be of use :-
4 x 128MB sdram DIMMS, registered type - as used in older servers.
4 x 256K (I think) 30 pin simms (labelled "PWA-DRAM 256K BD"). May be usefull for some older sound cards or machines?
The 30-pin SIMM are suitable for one of the few A600 1Mb chip RAM upgrade, albeit those normally comes with the clips already filled.
Fizzy
South Wales
Hi, do you have one of the 4mb sticks still available?
I only have one 4MB, and yes it is still available. Not sure how much postage will be to japan though - I'll have to check....
Marcelo
Rio de Janeiro
Hello, friend.
I'm in need of memory simm 72-pin for use on a TURBO-1230 Mk2. You still have some?
Fizzy
South Wales
Hello, friend.
Yes, I still have most of the memory available - didn't actually get many requests.
What size of memory are you after?
Marcelo
Rio de Janeiro
Hello, friend.
It may be 32 or 16 or 8. I would be grateful if you could give me one of each module. :D
Fizzy
South Wales
Hello, friend.
I could give you a couple each of 16's and 8's. Unfortunately the 32's are in fact smaller SODimms from a laptop, so won't work in amiga accelerators.
Marcelo
Rio de Janeiro
A pair of 8mb and 16mb of others would help me a lot.
PM sent.
Fizzy
South Wales
Ok - both memory requests have been sent out today. Should hopefully be with you in a few days.
