Closed Gonbes GBS-8220, VGA-RGB adapter, Datalux mouse
  • Thread starter Thread starter pedrorq
  • Replies Replies 5
  • Views Views 1594
pedrorq
Ireland
Galway
Hi, I have a trio of items for sale. Worldwide postage is included in the price. No, not trying to make money here, just to empty the house a bit :D
First we have a Gonbes GBS-8220, a card that can be used to work as a flickerfixer, converting the 15KHz of the Amiga into an output frequency compatible with more modern monitors. It has 2 VGA outputs unlike its "younger" sibling the GBS-8200. The cables are included and although you'll need a female DB23 connector and some soldering skills to make the cable "amiga-compatible", I'm also throwing in an old shell for the connector.
Bought it a month ago, never used it. €22 shipped - SOLD to voyager_1701e
Then we have an Amiga RGB 23DB (female) to 15 VGA (female) adapter. You can use this to plug your Amiga directly into the VGA port of a monitor that supports 15KHz. This is from vesalia.de and was bought about 3 weeks ago. Works perfectly.
Apparently vesalia makes these adapters with 25DB shells instead of 23DB, so I improved the adapter by widening one of the side holes on the shell so a long side screw can be fitted. You can call this an "adapter 2.0" :) €10 shipped
Finally, a good old Amiga mouse by Datalux. I have no idea where this is from but I got it with my A1200 in 2008 or so and it has worked ever since. €6 shipped - sold to izi
