I bought this DF0 selector: http://amigastore.eu/en/485-df0-selector.html
and this external drive Gotek cable: http://www.ebay.fr/itm/External-Ami...982351?hash=item3f6821c18f:g:UBMAAOSwtUtXA4N6
My hope is to use the Gotek as DF0 when I switch the drive selector to 'On'. My Amiga 500 has kickstart 3.1.
No matter what I try I can never boot to the Gotek when connected externally. I prove the Gotek works because when I connect to the internally by replacing the floppy drive it works great. I tried the DF0 selector to on and off with no difference. I also tried booting to DF1 using the boot options of kickstart 3.1 and it does not work.
I also tried disconnecting the internal drive while the Gotek was connected externally and no luck. The Gotek has a jumper on S0 which I believe is correct.
Any suggestions please? I have tried everything I can think of at this point!
Thank you!
Thank you!
