Hello my fellow Amibayer's,
The faster hack is the better hack! :-D
Here are some benchmarks from a project I've been quietly working on these past few months. The end result is a combination of software patching and hardware hacks producing faster benchmarks.
Indeed, we are now very close to the Zorro2 Max. transfer rate!
System specs:
- A2091 14MHz SCSI mod + 14MHz patched Guru ROM
- A2630 54.2 MHz mod + 4MB 32bit Fastmem
- Compaq 550MB SCSI-2 HD
- SYNCH transfer mode enabled!
Note: NTSC Zorro2 Bus CLK = 7.16MHz (PAL = 7.09MHz).
P.S. It's entirely up to Mr. Babel to authorize the release of any patched ROMs.
Guru2091_14MHz V1.0 released!
Guru2091_14MHz is software patch which enables 14MHz driver operation. Now you can enable SYNCH mode post boot (Please read the text file after you extract the archive). Happy benchmarking everyone!
Note: The DMACSCLK part of this thread was removed since it was never a reliable hack.
Here is the link to images and downloadable files:
http://eab.abime.net/showthread.php?p=963856
System specs:
